Author Topic: Do I have the right parts?  (Read 2006 times)
Offline Jocigar
Re: Do I have the right parts?
« Reply #15 on: August 09, 2012 - 10:48:51 PM »
thanks  :wave:
I am in over me head this stupid flywheel  :banghead:    I have the repair manual, guess I will have a look  :bricks1:
« Last Edit: August 09, 2012 - 10:50:59 PM by Jocigar »
« Reply #16 on: August 09, 2012 - 11:33:49 PM »
You need the performance engine book , MoparAl may be able to scan the page you need , I have the same book but not here with me  , the engine balance was different between every external balance engine  the 340 , 360 , 400 , 440 cast & 440 6 pack were all different weight offsets so the flywheel cannot be swapped between them , the best route is either to balance everything as the engine is assembled or have the engine internally balanced as it si built . My Race 440 used 6 pack rods but there were severely lightened & polished & the crank was weighted so everything was balanced properly internally . Using a new flywheel drilled correctly will get you close as long as you do have the 6 pack rods & correct pistons in the engine now , if you have a lighter piston which I would recommend then it will still be off .
 I am not trying to depress you but it is better to find out now than once it is all together & vibrating .
Offline Jocigar
« Reply #17 on: August 10, 2012 - 10:54:29 AM »
the engine was a complete block minus intake and has already been professionally rebuilt back in the 90s for around $1,200.
It was factory stock, and rebuilt with same parts minus a mild purple shaft cam.... so I need to believe it has correct rods and pistons.
How do you go about making sure FW is balanced/drilled correctly for a 440-6pk...  is there a machine that does this?      I could have the correct flywheel that came with the car, i am just not sure because of the 20 year time laps  :faint:
I do have a 3" thick service manual...  what is the specific name of the engine book, does amazon have it
thank you!!!!
« Last Edit: August 10, 2012 - 10:56:22 AM by Jocigar »
Offline Jocigar
« Reply #18 on: August 10, 2012 - 05:06:14 PM »
i found this on the web.  someone also mentined that the bb sixpack fw has a half moon chunk missing out of it rather than wieghts.
both check out;  two thru-holes at .370" diameter and a chunk missing.    It must be correct! since one came with car and I dont have any others sitting around.      agree  :clueless:
« Reply #19 on: August 10, 2012 - 05:07:57 PM »
Makes sense to me  :2thumbs:
Offline Jocigar
« Reply #20 on: August 13, 2012 - 02:22:01 PM »
Looking at clutch discs, my old one is a full 11" with 18 spline.. not sure on the make.
Mcleod organic $150 range, 10.95"
Mcleod alum/kevl $210 range, 11"
do i need to or should I spend more on the alum/kevlar version ?
« Reply #21 on: August 13, 2012 - 03:12:48 PM »
Why not give McLeod a quick call on the tech line & see what they recommend as best fit for you
Offline Jocigar
« Reply #22 on: August 13, 2012 - 05:02:04 PM »
 :thumbsup: Ok, they recommended organic for a stock weekend driver.
They resurface and rebuilt the pressure plates with new springs for 90, think I may take them up on that and have them ship it back with new clutch disc.    unless you think its a waste of money, it seems worth while.
« Reply #23 on: August 13, 2012 - 06:10:43 PM »
makes sense to me  :2thumbs:
