Well the chain should be tight , Edelbrock may have sent a chain for something else like a mid ford 400 or something . Mopar Perf has a spring loaded chain tensioner available for the small block also .
retarding the cam will increase top end power slightly , not sure if that is what you want . the crank gear is supposed to fit in all of the 3 grooves though so it sounds more like a poor quality part .
