Author Topic: Power Probe III  (Read 531 times)
Offline daveh
Power Probe III
« on: May 21, 2012 - 04:18:04 PM »
Hey Guys,
Has anyone ever used these Power Probes?  They seem pretty cool.  If you did what do you think of them?
http://www.ebay.com/itm/200626345801?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
http://www.ebay.com/itm/330583718609?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
Thanks
Re: Power Probe III
« Reply #1 on: May 21, 2012 - 07:20:54 PM »
never used or sen that , I just use a $5 analog multimeter
Offline joelson6
Re: Power Probe III
« Reply #2 on: May 23, 2012 - 11:12:51 AM »
i don't get it  :clueless:
Offline gkring
Re: Power Probe III
« Reply #3 on: May 24, 2012 - 12:10:27 AM »
I use mine all the time. Hardly every pull out the multimeter or test leads anymore. With one touch you can check for power or ground, no flipping multimeter switches. It also can provide 12 volts as well as ground signals. Does it all except check resistance. Easy to test all relays, bulbs, switches, solenoids, etc right away without running test leads. Built in breaker so easy to check shorts as well. Only warning is it is very easy to put 12 volts to something you may not want to power up so don't get to crazy with the rocker switch and put 12 volts to everything trying to test something.
Greg
1970 Barracuda driver
Offline daveh
Re: Power Probe III
« Reply #4 on: May 24, 2012 - 02:19:29 PM »
Great information, thanks.
