There is a lot of proven combos to do this , firstly more CI is not always the answer , it builds shorter rod ratio / more of a race engine than a street brusuier , I prefer the 512 for street , tons of torque everywhere , very drivable .
- fOR OIL PAN i WOULD USE THE 6 qT hEMI PAN & PICK UP KIT FROM mANCINI
- oil pump should be a Melling HP /not high volume
- Water pump there are a lot of choices , Do not use the 440 source housing it is restrictive & causes heating problems
- the Victor intake is great but will not clear under hood , the Holley Street Dom is the best low intake .
- Heads are the big decision , Stock iron will limit the powerband to about 5500 rpm max , Indy Ez are a better choice & you can use the big indy dual plane intake with them .
Camshaft is a tough call , I use a custom ground flat tappet Lunati grind in most 512 builds , great vacuum & idle & over 400 ft lbs tq from 2400 -5400 rpm at the tires . between myself & Lunatis tech line we can narrow down a grind to suit your needs . The big thing is everything has to match so the intake cam heads , torque converter if auto , gearing all have to work together to get the most out of the $$ spent
