Author Topic: Power Steering Pump Replacement  (Read 1155 times)
Offline ghjedi
« on: May 24, 2012 - 03:04:38 PM »
I'm gearing up to replace my leaky power steering pump on my '72 Challenger.  While I'm there, I'm also changing out the old high pressure and low pressure hoses.
It's been a long time since I've done this job, so any tips and tricks to removing/installing the pump and the high pressure hose?
I see that the new high pressure hose comes with washers to prevent leaks, but does it need anything else to ensure a tight seal?
1 of 1 1972 Challenger 440 4sp Convertible Blue GB2
2012 Challenger R/T Classic Blue Streak Pearlcoat
Re: Power Steering Pump Replacement
« Reply #1 on: May 24, 2012 - 03:29:44 PM »
Is the pump bad or does it just leak?  You can pick up a rebuild kit for under $20.  It will come with all new 0-rings and a shaft bushing.  You need to take off the reservoir anyway.  That's the hardest part of the job...not bending the reservoir.
Offline 4 speed fish
« Reply #2 on: May 24, 2012 - 04:37:43 PM »
Get a rebuilt kit,Easy to do.I would walk you thru it if needed.
Offline ghjedi
« Reply #3 on: May 24, 2012 - 06:16:10 PM »
I agree with you there!  The new pump comes with a clear label about not prying on the reservoir.
It seems like a fairly straightforward job, but I know there is always room for surprises.   :working:
