Author Topic: 1972 rear seat belt pictures  (Read 2501 times)
Offline barryv
« on: May 27, 2012 - 11:13:50 PM »
hi, does anyone have pictures of the rear seat belts for a 1972 cuda,thanks
Offline Barracudadan
Re: 1972 rear seat belt pictures
« Reply #1 on: May 28, 2012 - 12:35:07 AM »
I have a 72. What are you looking for I can take some pics for you if you want.
Offline barryv
« Reply #2 on: May 28, 2012 - 09:43:31 AM »
hi, i need pictures  of what the rear seat  belts look like as well if possible, were they are mounted. thanks for your help
« Reply #3 on: May 31, 2012 - 06:52:31 PM »
Here are a couple pics I took hope they are of some use they are a bit blurry. Sorry they are so huge too posting pics on this board SUCKS! At least for me anyway I can never get it right!My seat is in I would have to take it out for pics of seat belt bolts. And with the results I have posting images it may not be good enough for what you are looking for. Hopefully others can give better pics for you.
Offline barryv
« Reply #4 on: May 31, 2012 - 09:45:55 PM »
thanks for trying.
Offline Grec
« Reply #5 on: June 01, 2012 - 02:02:43 PM »
As far as where they mount, I don't think it's possible to miss the mounting points...
Pull the seats out and you'll see a large bolt hole for each of the 4 seat belt parts. (2 on each side)
The retractors mounts on the outside holes, the belt/buckles mount on the inside holes.
1973 Challenger Rallye
- 440 Six Pack
- A833 4 Speed, 18 Spline
- FE5 Rallye Red on Black
Offline barryv
« Reply #6 on: June 02, 2012 - 08:43:23 PM »
my floor area was covered with sound deadener,so i couldnt easily find the holes. also needed a good pictureof what the rear belts look like.thanks for the replies
Offline Grec
« Reply #7 on: June 02, 2012 - 10:02:42 PM »
Hmmmm...
You can see the holes from the underside of the car. They will be on the surface that curves down in front of the rear end. They are good size holes... you'll see em. Two for each side of the rear seat, where you'd expect them to be.
Just get the rear end up, locate the holes and poke a screwdriver through. :-)
- 440 Six Pack
Offline barryv
« Reply #8 on: June 03, 2012 - 06:11:04 PM »
i found the holes. now i just need pictures o f what the rear belts look like. so if i come across some i  will get them.thanks
Offline Grec
- 440 Six Pack
Offline barryv
« Reply #10 on: June 04, 2012 - 10:32:19 PM »
