Author Topic: Keep blowing exhaust manifold gaskets- why?  (Read 5472 times)
Offline 66/72RAB
« on: May 28, 2012 - 10:27:04 PM »
Hey guys , looking for some suggestions?? - I am blowing exhaust manifold gaskets at a somewhat regular rate.  Right side is the culprit. Not sure it matters but car is a 72 , I am running a basically stock 340 with stock manifolds and a 2 1/2" TTI exhaust system. I am guessing that the manifold might be warped. Any other ideas or tips? - Thanks
Offline 72cudamaan
Re: Keep blowing exhaust manifold gaskets- why?
« Reply #1 on: May 28, 2012 - 10:39:22 PM »
I'm sure your guess is spot on. Have it milled and you'll probably
be good to go.
If I cant fix it, it's broke
Andy  (phukker whither)
« Reply #2 on: May 28, 2012 - 11:20:42 PM »
Your car didn't originally come with exhaust manifold gaskets.  Both surfaces were machined so no gasket was needed.  Once you get the warping issue resolved, you shouldn't need a gasket.
Offline 1of1
« Reply #3 on: May 29, 2012 - 12:50:05 AM »
Wow , never seen a motor from detroit that did not have manifold gaskets , were there other years or engines that did not have them? Like my 383/335 comando?
« Last Edit: May 29, 2012 - 12:54:49 AM by 1of1 »
1970 Cuda 383/335hp/4sp/V02
2006 FordGT40 Black Naked
« Reply #4 on: May 29, 2012 - 12:51:30 AM »
I agree , the reason you are blowing them out is because they were never supposed to be there , I use a thin layer of Ultracopper RTV & bolt them up
Offline Jim
« Reply #5 on: May 30, 2012 - 09:49:23 PM »
Factory did not use gaskets, but those were virgin machined surfaces. Milling might be in order, especially if the surfaces have been exposed to leakage for an extended period. They will corrode and erode.
SB heads are bad about leaking between the center ports. Not much clamping force there. I've had to have the sealing surface on cylinder heads milled quite a bit to get it flat again.
The thin layer of copper RTV will work to take out slight surface imperfections.
-Jim
"Relax, all right? My old man is a television repairman, he's got this ultimate set of tools. I can fix it. "
Offline rusty dodge
  • 74 challenger 440-727-3:55
« Reply #6 on: June 02, 2012 - 10:39:34 AM »
Make sure the flange is still thick. In this pic, the right port is thin or worn away. Pic is after I belt sanded all the ports flat, and thats all the thickness i could get from it. Used a pedistal type belt sander with a long wide belt.
Offline 66/72RAB
« Reply #7 on: June 03, 2012 - 09:49:58 PM »
 Appreciate the input guys. Here is what i did. Pulled the manifold off and checked it , it lined up nicely with a straight edge so I do not think this was the problem.  I am going with the idea that it is just not supposed to have a gasket. Put it back together with a thin bead of Ultra Copper as suggested. First trip out, so far so good. Thanks to all.
« Reply #8 on: June 04, 2012 - 10:31:16 AM »
A friend had the same issue , the gasket would last about 4-500 miles & fail , he left them out & was fine , the factory never used gaskets , I am sure you will be fine now .
Offline mrbill426
    • All Around Mopars
« Reply #9 on: June 06, 2012 - 10:08:13 AM »
Is this true for the big blocks too, no gaskets from the factory?
MOPAR or NO car!
'72 'Cuda 340, white on white
'72 Sebring; bracket project
'66 Imperial Crown; parts car
« Reply #10 on: June 06, 2012 - 10:13:15 AM »
yes . the only engine I can think of that used a gasket was the 340 with the heat sheild to protect the wires on the drivers side , it was a stamped steel gasket
Offline mrbill426
    • All Around Mopars
« Reply #11 on: June 06, 2012 - 10:30:50 AM »
Okay, thank you  :)
MOPAR or NO car!
