Any thoughts or recomendations if its normal or needs some work? When you grab the stearing shaft that connects to the power stearing unit , I am able to pull up and down on the shaft and it makes a clunking sound. Now it does not move much maybe a 16th , but at slow speeds I can hear the noise that is made when I pull up and down on the shaft. I also can get it to move a little bit by pulling up and down on the stearing wheel while in the car. It is def. not a tight sound it feels and sounds lose?
Should I rebuild the unit with new bearings or is there an adjustment or is it just a 40 year old car and I am exspecting to much?
Thanks in advance for any help...
