Author Topic: Anyone have any experience with 440 Source internals?  (Read 1337 times)
Offline Grec
« on: May 30, 2012 - 11:57:54 AM »
Looking at finally redoing my 440. 440 Source seems to have the best prices for higher end internals: Crank, rods and pistons.
Obviously they make them sound great in the descriptions, but I'm hoping that someone here has actually used them and can give some feedback.
How close were they to true drop in fit, balancing, etc?
Basically, would you recommend these for a Six-Pack motor that will be built up to 500-600hp. I'm not going too crazy.  :)
1973 Challenger Rallye
- 440 Six Pack
- A833 4 Speed, 18 Spline
- FE5 Rallye Red on Black
Re: Anyone have any experience with 440 Source internals?
« Reply #1 on: May 30, 2012 - 03:39:30 PM »
we have built 14 or more Strokers using 440 Source parts , , the crank will drop in without clearancing unlike the Eagle crank that took 4 hours of cutting the counter weights down , they use excellent brgs & rings , the rest is good quality but I would have a machinist check things before assy , we did have to chamfer some of the main brgs as the radius can be wide .
All of the strokers will built that we dynoed made well over 600 Gross hp some over 700
« Reply #2 on: May 30, 2012 - 04:21:35 PM »
 I bought ( and am in the middle of assembly) of a 451" kit from Muscle Motors. The price was good. Just don't let them "clearance" your wrist pins in the rods and tell them NOT to grind on your rods to balance them.I had to send back the set of rods they gave me.
 Other than that I'm quite happy with the machine work/clearances on the crank!
Offline PlumCraZRT
« Reply #3 on: May 30, 2012 - 06:23:09 PM »
I built a 451 stroker with their stuff... pretty mild street build and made ~500hp.
I agree with Chryco's response.  Their stuff is good quality, but the tolerancing is worth having someone double-check.  If you plan on using their heads (not mentioned in your post) think about ordering them bare and adding your own hardware.
mmmmm.... Mopar.... *drool*
Offline HP_Cuda
  • Mopar or No Car!
« Reply #4 on: May 30, 2012 - 07:09:10 PM »
To stroke or not to stroke that is the question!  :bigsmile:
Offline Cuda Cody
  • Vancouver, WA
« Reply #5 on: May 30, 2012 - 07:45:09 PM »
The one time I used them I was happy with the quality.  Should hold up to 700 to 800 easy is what my machine shop said.  Good quality stuff.
I kept everything stock except for the stroker kit.  Went from 383 to 438 and it dyno's at 402 hp.  The machine shop said with heads, bigger carb and headers it should make 500 to 600 easy.
Offline PlumCraZRT
« Reply #6 on: May 30, 2012 - 10:17:31 PM »
I forgot to mention that when I ordered my kit back in 2007 or 2008, the word on the street was to have it balanced by a shop (don't have 440 source balance it).  Apparently their tolerances were a bit looser than most shops would let by... I'm not sure if that's the case now.
Offline Grec
« Reply #7 on: May 31, 2012 - 10:19:01 AM »
Thanks for all the responses, guys. Very helpful.
- 440 Six Pack
