Author Topic: Carb adjustment...need some help  (Read 485 times)
Offline NCtrueconservative
« on: May 30, 2012 - 10:14:10 PM »
I got an Eddy on a 340. The timing is good on it, it idles perfectly, starts right up on first turn, and cruises really good. But when I tromp it cruising down the road, or on take off. The think studders for a second, and then takes off real quick.  How do I get rid of that delay? What adjustment do I need to try first? Like I say, everything else is real good...had my cousin who is a mechanic get it timed and adjusted good on idle the other day when he was over.
1973 Dodge Challenger Rallye (pictured), 340, Slap Stick
1998 Dodge Ram, 5.2, Black, tinted windows, dual exhaust, blackout headlights, tailights
Re: Carb adjustment...need some help
« Reply #1 on: May 30, 2012 - 11:09:03 PM »
I would check the float levels , 7/16 is the spec but that is usually a bit low & they never seem to be right after shipping , next the usual problem is the squirter is too small , unfortunatly Eddy forces you to buy a kit of 3 even though all you ever need is the bigger one .
