Author Topic: Dreading these ball joints ***Update, Help!***  (Read 10092 times)
Re: Dreading these ball joints ***Update, Help!***
« Reply #60 on: June 11, 2012 - 03:50:38 PM »
okay, another question.  When I put in my new camber bolts when putting the UCA back on, how do I get them adjusted right where the alignment will be pretty close...I mean close enough where I could drive the car 5 mins down the road to the alignment shop?
Just use a level to get the camber close, and use a tape measure to get the toe in to within 1/8" would be good!
Offline NCtrueconservative
« Reply #61 on: June 11, 2012 - 04:07:05 PM »
A level across the UCA?
1973 Dodge Challenger Rallye (pictured), 340, Slap Stick
1998 Dodge Ram, 5.2, Black, tinted windows, dual exhaust, blackout headlights, tailights
« Reply #62 on: June 11, 2012 - 05:22:08 PM »
No on the rim top to bottom
« Reply #63 on: June 11, 2012 - 05:57:47 PM »
I set mine, & read where others did the same, by rotating the rear all the way in & the front all the way out. This gives maximum pos. caster, my camber just happened to come in about perfect. Also when you get an alignment find the specs posted here for use with radial tires, to factory specs are for bias tire & don't work very well. http://www.cuda-challenger.com/cc/index.php?topic=57753.msg595650#msg595650
I encourage you to go ahead & replace the lower control arm bushings and strud rod bushings...On my 50K car the lower bushings were all that shown any real wear.
« Last Edit: June 11, 2012 - 06:02:19 PM by Bullitt- »
« Reply #64 on: June 11, 2012 - 09:20:12 PM »
Okay gocha  :thumbsup: And Bullitt will do, appreciate those specs.  Had the other side old ball joints out and new ones in in about half a day! Amazing how one side goes soooo smooth, and the other is a real headache.  But hey, I've really learned alot through this whole process and thats what its all about right?  :D
« Reply #65 on: June 11, 2012 - 09:26:37 PM »
We all learned doing it , I for sure was not born with this knowledge  :2thumbs:
« Reply #66 on: June 12, 2012 - 12:28:43 AM »
I say if you don't enjoy the process, even if it's frustrating, your in the wrong hobby.
« Reply #67 on: June 12, 2012 - 08:06:17 AM »
I find with most people it's confidence they are lacking not so much the mechanical ability. You just have to say to your self " it's broke now and I can't break it anymore " then have at it!  Worse case scenario is it might require a few extra parts, big deal! It's still cheaper than having to pay someone else to do it.  I usually find too that if you need a special tool to do the job ( eg, ball joint socket) it's usually cheaper or works out about the same to buy the tool and do it yourself. Then the next time you need to do that job the tool is already paid for. :2cents:
« Reply #68 on: June 12, 2012 - 09:26:32 AM »
I have a slightly different viewpoint , I figure someone else built it , I should be able to take it apart & fix it if someone else can . Buying the tools just makes sense , , I always end up using the tool agin helping someone or doing a different car that I own down the road .
« Reply #69 on: June 12, 2012 - 09:32:13 AM »
All great advice guys! And God blessed me with the socket. The head of the local Mopar club who is a mechanic had one and let me borrow it
