Author Topic: How hard to replace passenger side door glass on 70' Cuda  (Read 1390 times)
Offline Mopar Thunder
« on: May 31, 2012 - 12:06:41 PM »
No having a lot of interior knowledge, how hard is it to replace the door glass on a 1970 Cuda?  Are there any tricks?
Offline calicuda70
  • 2 evil 70's and 1 BAD 11
Re: How hard to replace passenger side door glass on 70' Cuda
« Reply #1 on: May 31, 2012 - 04:44:18 PM »
ive done my challenger and cuda both are very simple just a little time consuming just take ur time and it will come out with ease remove the rear track completely and disconnect from the front track and regulator then it should just slide up angle it just right and remove the rear part of the glass 1st with the fwd piece slightly down. theres a ruff idea. hope it help im sure others will chime in on it.
james
70 'Cuda 5.7 Hemi protouring resto
70 Challenger 360
11 Challenger SRT8 392
Offline dutch
« Reply #2 on: May 31, 2012 - 05:40:22 PM »
remove window felts and upper guides. unbolt mechanism rail from glass.  It comes out with the front rail attached to the glass. Loosen rear rail so it can move around a bit.
« Last Edit: June 07, 2012 - 05:36:43 PM by dutch »
*** Bart ***
« Reply #3 on: May 31, 2012 - 09:00:52 PM »
When the glass is rolled down almost to the bottom, is the most accesible on unscrewing the 2 screws that hold the glass onto the track.
Bob, 4 SpeedFish and I did both of mine last week.
I used to do them myself along time ago. I was a little rusty this time. Was like re-learning spanish again I took in H.S. It really helps if you have somebody there as a second set of eyes.
« Reply #4 on: June 07, 2012 - 12:20:49 PM »
Thanks for all the advice.  Once I order the glass I will give it a try.   :cheers:
