Iginition source for electric choke in 1973 challenger?
Author Topic: Iginition source for electric choke in 1973 challenger?  (Read 1360 times)
Offline bugsdad
« on: May 31, 2012 - 04:20:32 PM »
This is a schematic I found for a 1973 Challenger like I'm working on for my dad. It looks like a Dark Blue wire where the old "electric choke control" hooked up had a junction where a bunch of ignition hungry parts where hooked up. Where is this and is it a a good spot to run the electric choke on the holley i'm putting in?
Thanks!
Re: Iginition source for electric choke in 1973 challenger?
« Reply #1 on: May 31, 2012 - 10:38:26 PM »
Yes , there is a dark blue feed to the "choke Heater", you should be able to trace it near the ballast resistor or just connect into the blue wire at the ballast
Offline 360FISH
  • BS23H3B567746
« Reply #2 on: June 01, 2012 - 12:47:21 AM »
I found mine by tracing the blue wire from the alternator back to the electrical block.  There was another unused blue wire coming from the same plug-in hole at that position.  It tested correctly.   You can also splice into that same blue wire comng from the alternator.
Enjoy!
1973 ‘Cuda   Semi-Pro Touring
360 SB - 518/OD auto tranny - FAST EZ EFI - Edelbrock Fuel sump - HHR fan
Hella H4 headlights on relays - 97 Dodge Avenger seats - Chin spoiler - Bumpers pulled in to ’72 offset
Build: http://www.cuda-challenger.com/cc/index.php?topic=74674.0
Offline bugsdad
« Reply #3 on: June 01, 2012 - 08:04:47 AM »
Thank you guys so much!
