Author Topic: E-body part out (one 73 Cuda and one 73 Barracuda)  (Read 30796 times)
Offline Jack Barnes
Re: E-body part out (one 73 Cuda and one 73 Barracuda)
« Reply #60 on: October 27, 2013 - 07:32:24 PM »
Is the 73 passenger seat still available ? I also need the hood latch for this car.
Offline mikeyscuda
« Reply #61 on: November 22, 2013 - 05:50:30 PM »
is the front bumper and brackets still available? also i would like more info on the two doors.
Thank you
Offline diyhemi.com
  • Formerly Yellowfin
    • DIYHEMI.COM
« Reply #62 on: December 04, 2013 - 08:26:39 PM »
Most of these parts are gone. I do have the 73 brake booster you speak of in my attic, complete with master and firewall bracket.
Sent from my iPhone using Tapatalk - now Free
1970 Barracuda Gran Coupe, gen III project (Cone Killing Cuda)
Offline amethyst3500
« Reply #63 on: December 05, 2013 - 08:31:25 PM »
I'm looking for rear frame rails for my 1972 Challenger I believe they are the same.
Offline tuffet1
« Reply #64 on: December 05, 2013 - 09:41:12 PM »
how much for the valance insert and do you have a brake booster with bracket
« Last Edit: December 05, 2013 - 09:48:35 PM by tuffet1 »
Offline redo1973
« Reply #65 on: December 05, 2013 - 09:56:22 PM »
is the heater box still available?
Offline v21jeff
« Reply #66 on: December 06, 2013 - 09:18:43 AM »
Might you have proportioning valve?
Offline diyhemi.com
    • DIYHEMI.COM
« Reply #67 on: December 21, 2013 - 08:00:00 PM »
Valance insert and heater box available. Proportioning valve is gone
Insert I can do $25 plus the ride
Heater box I can do $30 on for non AC
Offline Dfr360cuda
« Reply #68 on: December 23, 2013 - 07:53:48 PM »
Hi
How about a better pic of rear bumperettes ?
Thanx
Dan
 :burnout:
Offline Dfr360cuda
« Reply #69 on: December 23, 2013 - 07:56:22 PM »
Hi
I took mine off and misplaced one of them
Thanx
Dan
 :burnout:
Offline 734406cuda
« Reply #70 on: December 29, 2013 - 07:21:27 PM »
Are the braces on the cowl that you tack weld the inner fenders to Ans do you have a lower radiator support for 26" call or text 918-605-4889 thanks Andrew
Offline diyhemi.com
    • DIYHEMI.COM
« Reply #71 on: December 31, 2013 - 11:07:03 AM »
I will try to get pics of the bumperettes soon. I have a lower 26" radiator support but it is bent. The side support (needed to convert from 22 to 26" is in great shape though
Offline 734406cuda
« Reply #72 on: December 31, 2013 - 08:21:41 PM »
On the supports I'm needing the 4 strips that tack to the cowl/firewall Ans the inner fenders tack to them and how bad is the support bent
Offline diyhemi.com
    • DIYHEMI.COM
« Reply #73 on: January 10, 2014 - 05:45:42 AM »
The fender to cowl prices that I have were bent to get the upper cowl section off. I slowly bent them by hand and spot weld cut the welds they may be reusable. I need to go check storage this week to see what I have. As far as the lower support, it's bent on the drivers side. My parts car has a straight one and I was going to swap it out with my current 1970 one. Thus I would be letting the 1970 lower support go if you wanted it.
Anyone interested in a solid complete front clip with a 26" radiator opening and AC lower cowl? Subframes good.
Offline hotrodded1970
« Reply #74 on: March 03, 2014 - 02:26:39 AM »
do you have the inner rear  fender housings still available?
Proud Owner Of a Numbers Matching One Owner 28,000 orginal Miles 1970 Challenger 383. Oh yeah Miles Documented
