Author Topic: seven blade fans  (Read 786 times)
Offline rattlesnake
  • Rattlesnake
seven blade fans
« on: June 04, 2012 - 09:31:03 AM »
On a mopar seven blade clutch fan, when you are looking across the front of the blades in a parallel fashion, are all the blades on the same plane or does one stick out further than the rest?  I know when looking at the fan from the dead on front the blades are offset but not sure about the front when looking down or across the tips.  I have a fan but it might possibly have a bent blade.  Does anyone know or can someone check thier set-up please.  Can these be straightened and has anyone ever done it.
keep honking I'm reloading
Re: seven blade fans
« Reply #1 on: June 04, 2012 - 10:33:22 AM »
it is bent , I am sure it could be tweaked back
Offline rattlesnake
  • Rattlesnake
« Reply #2 on: June 04, 2012 - 10:37:59 AM »
thanks dude, you are a wealth of knowledge.
