Author Topic: Wider Tire Size  (Read 5419 times)
Offline Mopar Thunder
Wider Tire Size
« on: June 04, 2012 - 03:34:55 PM »
My wife has a 2012 R/T and would like a bit wider tires. My wife has stock tires on it now, 245/45/20.  Has anyone put wider tires on there's?  What size would fit w/o any alteration?
« Last Edit: June 05, 2012 - 08:55:36 AM by Mopar Thunder »
Re: Wider Tire Size
« Reply #1 on: June 05, 2012 - 10:17:37 AM »
I know some people have gone from the 8" rims out to 10 on the rear with a wider tire , not sure exactly what fits though
Re: Wider Tire Size
« Reply #2 on: June 05, 2012 - 06:24:05 PM »
She doesn't want anything really wide but maybe a 275/45/20 but I know she has too be careful of the turn radius upfront if she wants them there also. I was just wondering if anyone has changed them out already.
Offline fantum
Re: Wider Tire Size
« Reply #3 on: June 05, 2012 - 06:34:15 PM »
Let us know what you got, then post lots of pics 'cause you know.....
 :useless:
Offline TA340-6pak
Re: Wider Tire Size
« Reply #4 on: June 19, 2012 - 09:53:21 PM »
275/45 20 will fit no problem on the rear.  The front is a different story with stock wheel and offset.  Issue is the upper control arm stud.  It comes real close to hitting top inside area of the tire.  My front wheel is 9" wide with a +25mm offset and the 265/40 tire I have is real close to that stud.  There are guys running stock SRT wheels with 275's but some are running spacers.
"It does not matter if you win by an inch or a mile, Winnings Winning"  - Dom Torreto
My Other Rides
2009 Brilliant Black Challenger 6 speed SRT 8 w/Kenne Bell SC (PB - 11.725 @ 118mph   1.74  60 ft)
1992 Mustang Vortech Powered 306 (PB - 11.77 @ 119mph   1.59  60 ft)
1970 Challenger TA
2013 Grand Cherokee SRT 8
2012 Cadillac CTS V Coupe
Offline Jamie
Re: Wider Tire Size
« Reply #5 on: June 26, 2012 - 10:21:46 PM »
i tried 275-40-20 on our 08 r/t chrger and no rubs. also is close to same height as 245/45. so speedo/gearing will not not be different
I will finish a project.I will finish a project. I will finish a project.
70 barracuda plum crazy
( current goal is to keep just one car) AND FINISH IT!
08 charger r/t  w/road & track package
2011 silverado
Offline ek3
Re: Wider Tire Size
« Reply #6 on: August 16, 2012 - 07:53:59 PM »
i made a post about the use of tires for hi speeds , what type of tire would meet those spes  ect. i thought it was a tech type question.  when i come back i see my post has been locked/ moved ? i thought it was because it was about tires and they corrected my mistake .  but then i see another post about tires and the person who moved my post actually responded to it. ??? not trying to start anything ,, i just don't understand which way is the correct way ???   BW.
