Something that has always bugged me about the cuda is how hard it is to put gas in the thing. The newer pump nozzles (I'm in CA.) don't fit in there, especially since the license plate flips up and blocks the nozzle from sealing against the filler neck. Pretty much the only thing that works for me is getting the nozzle in there as best I can, then pulling the boot back so the pump will start and then resting my head on the trunk lid and listening for the telltale gurgle when the tank is close to full - oh yeah, and also while only holding the fill handle about 1/2 way because anything more than that and the air blows gas back out the filler neck. I have all the vapor/EMS stuff hooked up on my car, all the lines are clear etc. I'm thinking about reversing the license plate so that it hinges from the bottom, maybe that would let the fill nozzle boot seal and keep gas from leaking out everywhere??
So do you have any hints on how you fill up without some strange ritual??
