Author Topic: Seriously though, how do you fill up your gas tank?  (Read 7982 times)
Re: Seriously though, how do you fill up your gas tank?
« Reply #15 on: June 05, 2012 - 07:49:43 PM »
my 71 Charger has the same issue , the plate is hinged at the top , I just reversed it so it folds down
Offline inviolet
« Reply #16 on: June 05, 2012 - 07:58:50 PM »
Don't laugh....I use a stick that I wedge between the plate and the car to keep the plate flipped open...helps a lot............. :bigsmile:
« Reply #17 on: June 05, 2012 - 08:48:01 PM »
Maybe Im just a hayseed hick but can someone explain to me WTH a vapor recovery nozzle is or what its purpose is? Never seen one here in North Cackalack
2 fold reason:
Safety and air polluction reduction.
http://www.mde.state.md.us/assets/document/factsheets/vapor_nozzle.pdf
http://www.deq.state.or.us/aq/permit/vapor/stages.htm
Offline msbaugh
« Reply #18 on: June 05, 2012 - 09:06:57 PM »
I have issues and I have a Challenger. The flip top cap really makes things difficult with the vapor seal on the pump... It won't seal so the pump always clicks and stops like its supposed to when your tank is all the way filled. I have to repeatedly pull the handle until it is positioned just right. I need a regular gas pump!!
Offline Gus cuda
« Reply #19 on: June 05, 2012 - 09:32:48 PM »
Aw man sounds like torture! I live in little California (aka Maryland ) and I'm not looking forward to this. This state seems to follow California in as many ways as possible. As for now I will gladly continue filling my car without hassle.
« Reply #20 on: June 05, 2012 - 09:45:53 PM »
Many people complain about emissions laws today.
This gas recovery is just another one.
I'm not here as some kind of tree hugging, law abiding Mr. Do gooder.
Heck, I'm building a Godzilla Smog Monster!
But I can tell you a story:
Back in 69" or 70', my family & I; Took a trip to L.A. from N. CA.
When we got over the top of the grapevine, (Hwy 5) the smog was so thick, we had to turn on the headlights along like everyone else just so we could see where we where going. It was so bad it was like driving inside of a sewage pipe.
So it's a pain in the Arse this vapor recovery system is. However I do think it does help. Especially down near SoCal.
Offline LAA66
« Reply #21 on: June 05, 2012 - 10:23:43 PM »
 I would guess the newer cars have filler tubes designed for the vapor recovery nozzles. As for us, just be sure to have a napkin ready for that inevitable Burp. :puke:
Offline joelson6
« Reply #22 on: June 05, 2012 - 11:00:49 PM »
i was just gonna say that if you have a flip top cap on a challenger you might as well remove it. back in 1990 when i first
got my '72. i put a flip top on it cause it was cool. and then i stopped at a gas station......... :stomp:  :swear: :stomp:  :swear:  :pullinghair:  :banghead:
it was quickly removed.
Offline GranCuda1970
« Reply #23 on: June 06, 2012 - 01:51:41 AM »
.....with all those air pollution standards they must go bat shart crazy and cannot sleep at night when a volcano erupts and shoot billions of metric tons of carcinogens into the atmosphere!!!
Offline joelson6
« Reply #24 on: June 06, 2012 - 02:49:23 PM »
that's natural, can't nothing about that. an act of God some would say.
gas pumps, another story, man does have control over that. (some.........control that is)
« Reply #25 on: June 06, 2012 - 06:12:37 PM »
Sounds like a business opportunity for someone to make up some "adapters" ?
« Reply #26 on: June 06, 2012 - 07:55:52 PM »
Only control over us and our wallets.  :roflsmiley:
Offline magicr
« Reply #27 on: June 06, 2012 - 08:00:44 PM »
Quote
I have a 73 Challenger with flip top, and don't have a problem, but I have to go slow, but I'm used to that as my boat likes to burp gas, if I don't go slow.
1973 Challenger Rallye
1971 Dart Swinger (sons)
Offline ntstlgl1970
  • T a c o c a t
« Reply #28 on: June 16, 2012 - 05:52:58 PM »
I think a lot of it has to do with the volume (speed) of the newer pumps. I didn't have this problem in the 90's. I think they move fuel in the tank so fast that the tank/evap/vapor system (even if you have one) is not designed to move the volume of air being displaced by the fuel back to the nozzle. I wonder if adding an "air" return from the top of the vapor seperator to the top of the filler neck that is about 3/8"or larger would help. If you ever look at the vapor plumbing on newer cars at the wrecking yard, almost all the hoses that return air to the top of the filler neck or to the vapor canister/evap purge system are about 1/2 to 5/8" so they are expecting a huge volume of air to be moved around. Compare that to the 1/8 and 3/8 lines that go to the vapor seperator in the trunk and that the vapor line coming out of the seperator to the engine has a restrictor in it as well..
