Author Topic: electric fuel pumps  (Read 705 times)
Offline Gumby
electric fuel pumps
« on: June 04, 2012 - 11:14:15 PM »
Just a quick question, if you run an electric fuel pump with no regulator on a carb, will it/ can it cause problems? Thanks.
{oo/-------\oo} In '69 I was twenty-one and I called the road my own. I don't know when that road turned into the road I'm on. Jackson Browne
Offline the_engineers
Re: electric fuel pumps
« Reply #1 on: June 04, 2012 - 11:18:38 PM »
It depends, but the short answer is "Yes". No regulator or return line means that the fuel pressure could overpower the needle/seat assembly and flood the bowl and spill gas into the engine.
Brooks
1971 'Cuda 360
2004 Infiniti G35 6-spd Coupe
« Reply #2 on: June 04, 2012 - 11:24:41 PM »
Some electric pumps are rated as street pumps , these usually put out about 6 psi unregulated & will work fine with a carb & no regulator , others are race pumps & put out much higher pressure requiring a reg to drop pressure before the carb
« Reply #3 on: June 05, 2012 - 04:05:40 PM »
My 2 pennies worth...
I ran an electric pump for one season. It was a Mallory, and was rated for the street, but my mechanical fuel pressure gauge was a steady 11 PSI. So don't always believe what a company tells you. I installed a regulator to get it back down to 6 PSI.
Offline high perf mopar
« Reply #4 on: June 05, 2012 - 10:55:55 PM »
always better to run a regulator,,esp with electric fuel pumps no matter what the manf says,,mines set at 5 1/2 lbs,no bypass..street mallory 110 comp pump..seen at upper left hand side of pic..with gauge..
1971 barracuda
440-6 shaker
chrysler 3x2 competiton carbs mech,what chrysler should have done.
b-5 blue
"you got yourself some motor there boy!" 1973,,white lightning.MGM studios burt reynolds
