Author Topic: NOS E BODY & NOS 426 PARTS  (Read 2590 times)
Offline marty mopar
« on: June 05, 2012 - 01:42:48 AM »
ALL NOS MOPAR:
2539086 Leafspring plastic interliner   =1948396  4.00 each
3573505 grille nameplate 1972-74 Challenger 35.00 each
3573589 black grille 1972-74 Challenger 285.00
R/L Outside door handles 70-74 E body 88.00 each
3580630 (same as 3580704) front drums/hubs 10 x 2.5 1971-72 E and B Body 100.00 each
3686094 RF bumper guard 1973 Challenger 55.00
3464058 Front bumper guard cushion 1970 Barracuda 22.00 each
3507459 Diff ring/pinion 3.91 8 3/4 1970-71 E and B Body 200.00
3549061 Diff Ring/pinion 2.76 8 3/4 1970 E,C Body 140.00
2998213 L hood scoop texture(insert) 1970-74 Barracuda 40.00 each
2962290 Front bumper guard cushion 1970 Barracuda 22.00 each
THE FOLLOWING ARE ALL NOS HOOD NAMEPLATES:
2998796 Cuda 383 1970-71 55.00 each
2998798 440-6 1971 Barracuda 55.00 each
2998802 440 Magnum 1970-71 Challenger 65.00 each
3443159 Cuda 340 1972 55.00 each
3443247 340 4 Barrel 1970 E body 55.00
3462489 L Hemi (shaker) 1970 Challenger 56.00 each
3691468 360 4 Barrel 1974 E Body 55.00 each
MORE NOS:
2947924 Glovebox lamp/switch 1970-71 E body 25.00 each
3402729 Pitman arm used/power steering 1973-76 E,B Body 70.00 each
3420179 Leafspring used/318,383 1970 E Body 85.00 each
3431533 2 Speed Wiper Motor 1972 E Body 85.00
3431606 2 Speed Wiper Motor 1973 E Body 85.00
3467051 "T" Auto trans shift handle 1971 E,B Body 70.00 each
3403848 Road lamp bulb 1970-71 Barracuda 28.00 each
each=price for one and I have more than one in stock
I have lots more NOS and Used parts,literature
shipping extra www.arizonaparts.com 480. 966 6683 mkolner14@hotmail.com
TO FIND ALL THE E BODY PARTS STOCKED TRY A SEARCH IN THE YEAR FIELD
     EXAMPLES:   B,J
                       J
                       B
                       1970 J
                       1972-74 B,J
                        ETC.
        B=BARRACUDA     J=CHALLENGER
NOS 426 HEMI PARTS
2406677 OIL PRESSURE RELIEF VALVE SPRING 1963 /426 2 5.00
2421370 AIR CLEANER COMPLETE REPRODUCTION 1963-64 /426 4 195.00
2465203 MANIFOLD HEAT VALVE STOP 1965-71/426 10 2.40
2468005 CONNECTING ROD BOLT 1965-66 /426 15 2.10
2468128 VALVE ROCKER SHAFT SPRING 1965-71 /426 15 5.40 EA.
2468196 SPARK PLUG TUBE SEAL 1965-71 /426 16 2.15
2530444 T/O BEARING 1965-66 /426 1 30.00
2532708 RF ENGINE MOUNT NORS U2402182 1965-71 /426 4 46.00
2658852 426 HEMI DECAL BLACK/WHITE 1970-71 10.00
2660673 REAR MOTOR OR TRANS MOUNT U2533145 1968-70 /426 8 53.00
2780525 PISTON PIN .003 1968-71 /426 13 14.50
2780534 EXHAUST MANIFOLD GSKT 1966-71 /426 10 5.00
2780572 CAM SPROCKET 1968-71 /426 2 38.00
2780629 CARB FLANGE GSKT 1967-71 /426 15 5.00
2785434 RADIATOR SHROUD 1967-69 R,W /383,440,426 1 65.00
2843177 TAPPET .0005 U.S. SEE P2843177 ALSO 1966-69 /426 1 10.00
2843178 STD TAPPET 1966-69 /426 4 10.00
2863722 GAS PEDAL RETURN SPRING U3462748 1969-71 /426 4 15.00
2899548 EXHAUST VALVE STEM OIL SHIELD 1967-71 /426 14 2.00
2899549 VALVE SPRING W/O INNER SPRING 1967-69 /426 2 6.00
3418238 VALVE TAPPET .0005 US 1970-71 /426 30 15.00
3418239 STD VALVE TAPPET 1970-71 /426 21 15.00
3418359 INTAKE VALVE PUSH ROD 10 5/8 LONG 1970-71 /426 34 13.00
3418491 VALVE SPRG/DAMPER 1970-71 /426 14 10.00
3462748 FRONT GAS PEDAL RETURN SPRG U2863722 1969-71 /426 4 15.00
P2836162 L STD PISTON/PIN 12.5 TO 1 COMPRESSION 1964-71 /426 1 45.00
P2836167 R .20 OS PISTON/PIN 12.5:1 COMPRESSION 1964-71 /426 4 45.00
P2843177 TAPPET .0005 U.S.(MECHANICAL-FOR RACE) 1966-71 /426 10 8.75
P4120808 SPARK PLUG INSULATOR 1966-71 /426 1 3.00
QTY is the number before the price.
Price is for one. Shipping extra.
 480 966 6683
 mkolner14@hotmail.com for replies
Offline jimynick
Re: NOS E BODY & NOS 426 PARTS
« Reply #1 on: June 05, 2012 - 11:19:45 PM »
I'm interested in the outside door handles for the 74, but I believe the cuda and challenger handles vary a bit. What are the ones you have and do they have part #'s? Photos? The message box is full, so could you just reply here? Thx.
