Author Topic: 245/60 on a stock 14" wheel?  (Read 1516 times)
Offline The4ork
« on: June 06, 2012 - 09:18:02 AM »
i have the stock skinny 14" wheels on all 4 corners  :banghead: unfortunately the car came like that. i dont have the $ to buy new tires and rims, and it needs new tires more than rims. so can i put a 245 on it?
Re: 245/60 on a stock 14" wheel?
« Reply #1 on: June 06, 2012 - 12:58:29 PM »
the stock 14" ralley wheel is only 5.5" wide , the tire mfg should have a recommended rim width but if the tire is a bit wide the edges of tire will not wear down evenly but you should still be OK .
Offline BIGSHCLUNK
« Reply #2 on: June 06, 2012 - 01:17:56 PM »
NIKKI had them on the front when I got her...no probs
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
Offline Super Blue 72
    • Phil's Super Blue '72
« Reply #3 on: June 06, 2012 - 10:15:39 PM »
On my stock 14" Magnums, not sure if they are 5.5" or 6" wide, when I went to National Tire and Battery, I think I was told the widest you can SAFELY mount was a 235/60-14.  He looked it up in a book he had.  Can you do it?  Sure.  Should you do it?  Up to you.  If the rim isn't wide enough, the center will bulge and as Chryco mentioned you won't get even tire wear.
Offline The4ork
« Reply #4 on: June 07, 2012 - 01:21:04 AM »
how wide is the stock 'wide' 14"?
its got 205/70r14's on all 4 right now-almost brand new. but one bulged out and blew :banghead: so i was going to get two new ones, wider and put them on the back. i can always get the wider 14's and put even wider tires on them and put them on the rear. or better yet get the 15" wheels just for the back?
Offline willard
    • 1970 Challenger R/T
« Reply #5 on: June 07, 2012 - 03:50:30 AM »
I've been riding a set of 4 245/60 R 14s on 5.5" rallies for 3000 miles -no problems although the width is on the edge...
https://picasaweb.google.com/lh/photo/zu1OzvHwmO42y3LoMB2Q8NMTjNZETYmyPJy0liipFm0?feat=directlink
1970 383 R/T SE
Offline triple_green
« Reply #6 on: June 07, 2012 - 09:51:21 PM »
I used to run 235 60 14s on 5.5 rims all the time. Not sure how big the width jump is to 245s.
1968 Charger triple green 383 HP all orignal restoration numbers match
