Mopar Performance 360 Magnum crate engine-More info, cheaper price.
Author Topic: Mopar Performance 360 Magnum crate engine-More info, cheaper price.  (Read 7277 times)
Offline migsBIG
  • I'm a llama!
A 360 Magnum engine from Mopar Performance that had about 800 miles on it when it was yanked for abigger, badder engine. As some of you know, Mopar Perf has canceled the small block magnum engines under 400+hp and what remaining stock is going for big bucks. They will sell you a new one at $10k but probably not what your budget is able to handle. Have had this one last couple years, but have decided to drop in a big block and is now for sale. Been indoor stored and ready for a new home.
Most sell for $5800+
selling this one for $3800, that's still cheap
also have blue engine crate for for an extra $300 with the purchase.
also, carb is not included.
also has a fresh heavy duty 727 auto trans for an extra $500
san jose ca
408-623-3290
migsbig @yahoo.com
may be willing to ship
Horsepower: 380 hp @ 5300 rpm
Torque: 410 ft-lbs @ 4400
Compression Ratio: 9.0:1
Block: Cast Iron
Crankshaft: Cast, 3.580"
Heads, Chamber Size: Cast Iron
Valves: 1.925" / 1.625"
Camshaft Lift: 0.501" / 0.513"
Dur. @ 0.050": 288 / 292
Intake: M1 Aluminum Dual Plane
The Magnum 380 crate motor head is a swirl port design that has smaller combustion chambers and a higher compression ratio (nominal 9.0:1). Different intake and exhaust port sizing flows more air without modifications to the cylinder heads. Breathing is enhanced with 1.925" intake valves and 1.625" exhaust valves. Overall package of smaller valves and better ports flow more air. Next, we slide in our .501" / .513" lift, 288/292 degree duration hydraulic roller camshaft, add a 4BBL carbureted M1® single plane intake manifold (with bosses over each runner for future MPI). We add special valve springs and a double roller timing chain as well as an MPP electronic distributor. The distinctive Mopar cast valve covers with 10 screws are added to the package, with an oil pan (center sump) similar to the Commando engines. It is recommended you add your own 750 cfm Holley carburetor and headers to complete the package. Dyno testing with a 750 cfm carburetor and 17/8" headers show horsepower output to be 380+ at 5300 RPM. Torque output is 410+ lb/ft at 4400 RPM, with over 350 lb/ft available from 2000 to 5700 RPM.
« Last Edit: June 12, 2012 - 05:18:27 AM by migsBIG »
Offline migsBIG
  • I'm a llama!
Re: Mopar Performance 360 Magnum crate engine-More info, cheaper price.
« Reply #1 on: June 12, 2012 - 05:17:28 AM »
also, might be able to arrange to drop off at sacramento, ca moparts at the park car show june 23rd.
Offline migsBIG
  • I'm a llama!
« Reply #2 on: June 13, 2012 - 10:54:41 PM »
also, if someone buys this engine, I also have a set of very nice 1968 340 manifolds I would include for an extra $400. I wanted to run these instead of headers as they would look nice and still flow good, while still giving good clearance for power steering and fast ratio pitman arms.
Offline migsBIG
  • I'm a llama!
« Reply #3 on: June 21, 2012 - 07:41:49 AM »
dropping price to $3300
Offline snipernuts
« Reply #4 on: June 02, 2013 - 10:05:03 AM »
just by a longshot, you still have the motor?
1964 Plymouth Sport Fury Con't 426 wedge
1965 Mustang Conv't
1969 Dodge Charger SE 340
1970 Lemans Sport Conv't 400
1970 Dodge Charger R/T
