Author Topic: Rattle with no solution?  (Read 5861 times)
Re: Rattle with no solution?
« Reply #15 on: June 09, 2012 - 12:03:05 AM »
shift linkage maybe ??
Offline 1of1
« Reply #16 on: June 09, 2012 - 01:12:28 AM »
Take everything out of the car that you can.  Spare, jack, anything in the glove box / console.  Have someone drive with you and find a road you can get the noise / rattle to happen on consistently.  Keep going over the road making the sound until you find out where it's coming from.  I've rode in the truck and upside down in the passenger seat to track down a rattle.  :pullinghair:
Any thoughts about the shocks? Maybe best to change them as they did sit for 10 years..?
1970 Cuda 383/335hp/4sp/V02
2006 FordGT40 Black Naked
« Reply #17 on: June 09, 2012 - 01:19:27 AM »
Have you checked out the upper rear shock mount holes?
If the shocks when they were first installed weren't tightened enough; the bolt would wallow out the bolt thru holes.
Offline Cuda Cody
  • Vancouver, WA
« Reply #18 on: June 09, 2012 - 02:06:14 AM »
Just take them off and drive around.  Won't hurt anything and doesn't cost you a penny to see if that's the issues.  The way you describe them it doesn't sound like they are bad, but easy to check.
Offline hooD
  • detroit iron
  • Motor City Made Muscle
« Reply #19 on: June 09, 2012 - 03:30:07 AM »
....check your front and rear universal joints.
« Last Edit: June 09, 2012 - 03:36:15 AM by hooD »
-Larry
member since AUG 2007
southeastern michigan usa
1973 'CUDA 340
original owner
37,117 miles
Offline hooD
  • detroit iron
« Reply #20 on: June 09, 2012 - 03:35:38 AM »
my front shocks were 38 years old when i changed them.  they were not making any noise.
changing yours would be good maintenance.
-Larry
1973 'CUDA 340
original owner
37,117 miles
Offline 1of1
« Reply #21 on: June 09, 2012 - 07:24:18 PM »
Thanks all for the input...I will try them ...... :worshippy
Offline LAA66
« Reply #22 on: June 09, 2012 - 10:10:16 PM »
 Maybe double check the bushing on the exhaust mounts. Mine had a rattle like that also. :2cents:
Offline Cuda54
« Reply #23 on: June 11, 2012 - 01:56:52 PM »
You could check the rear tranny mount and cross member. I know the rear tranny mount can rattle when it goes bad. I hope you find it.
Offline 1of1
« Reply #24 on: June 11, 2012 - 03:02:35 PM »
thanks I will check it tooo, so far no luck :clueless:
Offline johannes
« Reply #25 on: June 11, 2012 - 04:47:50 PM »
...When driving slow (in a long drive way )  there is a rattle sound coming from the tranny tunnel ( or the middle of the car to the rear....When you hit a bump at low speed I hear a clunking or a "can rattle sound ". thoughts????
Thanks in advance  :clueless:
As for the "rattle" at low speed on smooth tarmack;
Check your lug nuts?
....maybe some joker has put a rattling stone inside one of your your dogdish capsules?
The "can rattle" when hitting a bump....
The upper part of the rear shocks can sometime hit sideways against the shock lower part.
.....kind of like a drinking glass upside down in top of a pole...
A tab of "rubber-glue" between the parts will remove this noise....
also if you have anti sway bars,...check where this is connected to the car "frame".
General solution;
Throw a small person inside your trunk,...and keep him there until he can figure out this strange sound...
Offline 4 speed fish
« Reply #26 on: June 11, 2012 - 07:06:03 PM »
When I finished my car I have a rattle that I could not find.One day under the car I notice I did not tighten the tie down brackets on the frame rail.
Offline 1of1
« Reply #27 on: June 12, 2012 - 01:55:04 AM »
Where are the tie down brakets on the rails?
Offline Super Blue 72
    • Phil's Super Blue '72
« Reply #28 on: June 12, 2012 - 09:13:23 AM »
General solution;
Don't forget to feed him once in a while!  :roflsmiley:  :poopoke:
That actually is a good idea, I used to do that alot, but only with trusted people...  :sly:  Bring a Snickers bar in case....
If you can get the car up on a lift, just start grabbing things and shaking.  Try to duplicate the sound with the windows up and down.  If you hear it the same way with the windows up, it's in the car.  If you hear it better with the windows down, it's outside the car.
Also, place your hand or someone elses hand in the area where the sound is coming from to see if they can feel any vibration/bump against the floor to isolate if it's a tranny mount.  If it's a tranny mount, I wonder if it would make the same sound going from drive to reverse?  My brtoher's old Trans Am had a bad tranny mount that only made noise when doing about 25-30mph around corners, a lound banging under the console.
« Last Edit: June 12, 2012 - 09:17:42 AM by Super Blue 72 »
« Reply #29 on: June 12, 2012 - 09:15:42 AM »
Beside the fuel tank .
