Need a core for a rebuild?
1974 318: $100 oboBone stock engine from carb (2V) to pan, minus the exhaust manifolds. Heads have been removed to check out the engine. ~117,000 miles. Was a running when I pulled it from a '74 Dart Swinger parts car, but it smoked on startup. Valve seals let go, I was going to have the heads freshened up but when I pulled the heads I noticed some vertical scoring on the cylinder walls. Nothing that won't clean up at .030, but it needs a rebuild. I can send pictures if you want, but its just a dirty, greasy 318 core engine.
225 /6 with 904: $100 oboComplete, bone stock 225 out of a '74 Duster, although I was told it wasn't a numbers matching engine. Casting number is 280683-6, so it is still the forged crank, 5 freeze plug '68-'75 engine. Ran, but #2 has 0 compression. Leak down test put air into the crankcase, I assume its rings. Rest of the cylinders are fairly low, I didn't check any further since its more work than I want to deal with for a /6. Single barrel carb, adjustable rockers, basically a standard 225. The 904 attached to it shifts through all the forward gears, but wouldn't go into reverse. Could have been a linkage issue, I never checked it out because of the engine problems. Picture below (engine hoist not included
, but the valve cover is), I can send more if needed. Again- dirty, greasy, and otherwise ugly core engine.
Pickup only, I'm in the Sacramento area. The scrap yard is closer than the nearest shipping terminal, and they're not worth shipping anyway.
Just trying to see if anyone needs a core, otherwise I'll probably scrap them as I'm not going to build them.
Make me an offer!
