coat the eccentric bolts with Anti Seize !!
You know, I put anti sieze on those bolts 20 years ago, which was the last time I changed the control arm bushings. That made removing the eccentric bolt/washers VERY easy. Total time (Car was already up on stands) to remove both brakes, release t-bars, remove rotors, split the uca's from the knuckle's with a p-fork and remove the cam bolts and remove the uca's, .....less than an hour. Very satisfying when everything goes smoothly.
Very good advice - anti-sieze is your friend. pushed the cam bolts out with my finger.
