Author Topic: 1970 barracuda slant 6 to 440 'cuda transformation, structural reinforcements?  (Read 1781 times)
Offline nr1freak
  • Go catch a 'Cuda, If you can...
hi!
a few years ago i started restauration on a 1970 slant six barracuda. i wanted to pull out the 6cilinder engine and fit the allmighty 440, which i purchased in the meantime. along with the 8 3/4 rear axle, the K-member and the 4-speed gearbox
i've just about finished changing the rear quarterpanels, firewall, trunk floor, etc..)  but now i've learned that the more powerfull cuda's had structural reinforcements (which the slant6 version hadn't...) so now i'm looking for someone who has does this kind of transformation or any online explanation on where those reinforcements should be!
anyone?
Cuda's don't leak oil, they mark territory...
Offline DocMel
I did it on my 71    As far as structural, really none.  The Hemis had torque boxes, but I dont beleive the 440's did
As I did, I would upgrade the front torsion bars to a larger diameter, and if you dont have a front sway bar, install one.  The quality of handling and ride improved big time in my case..............
Offline 67vertman
  • Member since 9-23-2005
I am going from a 318 to a 440 with 500 hp.  I installed front and rear toqure boxes as well as frame stiffners.  Other than that the only thing they did at the factor was put a skid plate on the K-frame.  you will need to find a v-8 k_frame as the/6 wont work.
Offline usraptr
My '70 440 'Cuda came with front torque boxes from the factory.  FYI>  :2thumbs:
(Edited 8-1-17)
Offline nr1freak
do you happen to have any pictures of those frame stiffeners? (installed)
Offline 7071 challenger
  • All you need is Dodge!
http://www.cuda-challenger.com/cc/index.php?topic=62778.0
Here is a link for an old tread. If you go a few replies down, you will see some pics of the boxes installed.
Robert
here is a pic of the front torque boxes before installation.
Robert
