Author Topic: Pictures of battery cut off switch mount  (Read 810 times)
Offline AZDAN
« on: June 17, 2012 - 02:03:35 PM »
Can people post some pictures of how/where they mounted the battery cut off switch at the rear of the car. I was thinking of using one with a rod so when it is on the street I could remove the road. Anybody run a rod through the tail light? I have an extra right side housing that I could drill to run the rod through.
Re: Pictures of battery cut off switch mount
« Reply #1 on: June 17, 2012 - 03:03:51 PM »
Most are mounted near the battery in the trunk & use a rod out the rear for racing so it can be removed , I piece of angle iron works
