Author Topic: Rear Window centering clips  (Read 801 times)
Offline peterro
  • 70 Challenger in progress...
    • The Pistonhead
« on: June 18, 2012 - 12:43:54 AM »
Just installed all the trim clips and put the centering clips in at the lower corners like the picture below. Wanted to make sure this is correct before I make the call to have the glass installed. Is this clip in the right place oriented correctly? Haven't seen any pictures and only a few references.
Thanks.
Offline 67vertman
  • Member since 9-23-2005
Re: Rear Window centering clips
« Reply #1 on: June 18, 2012 - 11:35:43 AM »
They look good peterro.  Remeber, they were placed by line workers so they didn't measure anything.
Offline publicbottle
« Reply #2 on: January 07, 2013 - 04:52:50 PM »
Hi, I know this is an old post however I would like to know if the clips do the same function as the small rubber blocks?
I have the rubber blocks, but not the clips......and for some reason or another I thought the rubber blocks where to go on the front windshield?
Thanks for the help!! :1zhelp:
Offline 72cudamaan
« Reply #3 on: January 08, 2013 - 01:35:24 PM »
Same function! Yes the blocks normally go on the front and many people don't even is the metal clips
on the back. Just some sort of spacer, though I would personally use the clips.Just easier IMO.
If I cant fix it, it's broke
Andy  (phukker whither)
