Author Topic: 70 Barracuda gran coupe staying a gran coupe few questions  (Read 1471 times)
Offline Haddixj
I just picked up a bunch of stainless from a guy on CL, rocker moldings, top of door trim, one piece of rear window trim, and some other stuff that I cant identify. it looks like vinyl top trim but I matched it to mine and it isnt.
this is the rocker moldings and dash with the vents I need to convert mine to AC
they have two female ends on it.
what are the curved ones in the pics?
and the straight ones?  They fit the rear quarter going rear to behind the door but I have no clue.
I also got the plastic map light thing that goes under the dash with the switch and socket for the bulb. Mine has the wire for it but my manual vents handles are screwed to the dash there.
All in all I most of the special trim I need, now I am just missing the top of the rear quarter windows.
thanks for your help
Jason
Offline 4 speed fish
Re: 70 Barracuda gran coupe staying a gran coupe few questions
« Reply #1 on: June 21, 2012 - 10:34:15 PM »
The long thin ones are the cuda  tail panel trim.
Offline Haddixj
« Reply #2 on: June 21, 2012 - 11:06:14 PM »
It is straight where as the tail panel is curved. Do you have any pics of it?
« Reply #3 on: June 22, 2012 - 02:15:45 PM »
They are the top and bottom pieces of the tail panel trim.You are missing the C shaped corner pieces.
Offline AARuFAST
  • AARuFAST
« Reply #4 on: June 22, 2012 - 07:43:18 PM »
If and when u have ur dash redone they can change ur dash to an A/C.  U will need to find the A/C vents.
Good hunting.
1970 AAR Cuda
" I Want to Ride "
it was the most boring
2 minutes of my life!!!!"
Offline Haddixj
« Reply #5 on: June 22, 2012 - 08:15:02 PM »
The dash I got has the vents in them in good shape. From what I have seen they are not repopd
