Author Topic: Vacuum Booster Question..  (Read 752 times)
Offline dusty
« on: June 23, 2012 - 06:00:07 PM »
The car I'm  working on had the original vacuum booster. Other than surface rust it looks ok, but is there a way to test it to see  if it works before I paint it? Forty years of brake fluid had caused a little rust...
Should it be okay?  I want to paint  it!!!!!!!
Re: Vacuum Booster Question..
« Reply #1 on: June 23, 2012 - 09:14:56 PM »
connect a hose to it & suck on it to see if it holds vacuum
Offline tman
« Reply #2 on: June 23, 2012 - 10:01:35 PM »
The key word is HOLD.  Might want to change the check valve.  Sometimes that grommet leaks.
« Reply #3 on: June 24, 2012 - 11:38:46 AM »
What year of car are you working on?  1970 boosters were painted gloss black as an assembly.(booster and master cylinder assembled and then painted)  71+ that had the Midland Ross boosters were zinc dichromate plated.(yellowish gold plating)
You can have the booster rebuild.  I sent mine to Booster Dewey.  He replated it the correct finish as well.
