Our '01 Sebring is pulling to the right slightly when brakes applied at lower speeds, the steering wheel jerks about an inch although the car stops fairly straight. It does not seem to do this at higher speeds, I even made panic stops from 50+ to the point the wheels were starting to lock.
Car tracts true, tires are inflated correctly and show no sign of uneven wear, feeling the wheels after a test drive there seems to be no noticeable difference in temperature. I put the front on jackstands to inspect & find nothing unusual, plenty of pad all about the same thickness. Ran the car on jackstands & the same thing happens, steering wheel deflects to the right noticeably in drive when the brake is applied BUT if done in reverse the wheel deflects to the left (that really has me
Nothing I have found on the internet suggests what the cause of this problem might be.
Suggestions appreciated
Wade
