Author Topic: Proportioning valve issues with disc swap?  (Read 1974 times)
Offline MoparDealer1971
  • CDRJ Dealer
« on: June 29, 2012 - 11:41:27 AM »
I installed the disc brakes from a 1976 Dodge Aspen station wagon (V8) on my 71 Challenger.  They are the smaller 10.5in I believe, not the larger C-body rotors.  I simply installed them, no booster, no proportioning valve.  As of now the car stops fine but it seems like the back brakes grab more then they should.  Would this be because of the drum/drum valve?  For example, I cannot power brake.  Yes, I know, this means I need more power...I am working on that.  But I was pondering it the other day...maybe its the brakes!?  If I come down on them HARD the rears lock first.  So, I guess these are my questions
Would the drum/drum valve cause uneven pressure with extra going to the rear?
What are my options for a new valve?
What are my options for later model or other conversions for power brakes?
From what I understand I can go up to the C-body rotors by just getting caliper mounts and the larger rotors...its this true?
Thanks!
1971 Dodge Challenger - 2010 Plum Crazy Pearl, 318 4-bbl, 904, 2.5in Pypes Performance X-pipe exhaust, Hemi torsion bars, 2in rear drop springs, Hellwig Motorsports sway bars, 11.75in Drilled/Slotted front brakes
Re: Proportioning valve issues with disc swap?
« Reply #1 on: June 29, 2012 - 01:03:22 PM »
Rears locking first is pretty much the norm for these cars. You can put an adjuster in the rear line or replace the whole prop valve with an aftermarket. Brads70 put a wilwwod adjustable prop valve in his car.
  • CDRJ Dealer
« Reply #2 on: June 29, 2012 - 03:59:33 PM »
I think mopar might have an adjustable available as well.  I will look into that.  I suppose you set those by feel or is there some sort of method?
Anyone ever put a later model power booster on?  The period boosters are sorta hard to find and $$$.
« Reply #3 on: June 29, 2012 - 07:20:15 PM »
http://www.cuda-challenger.com/cc/index.php?topic=85620.0
 CHECK HERE Brad show the proportioning valve he used , you also need to remove the residual pressure valve from the master , it is behind the brass insert the flared line seals against , I use a threaded screw to pull it out with vice grips & then re-install the insert once the rubber valve is removed
« Reply #4 on: July 02, 2012 - 10:09:23 PM »
My local mopar dealer sold me the Wilwood adjuster.  :2cents:
