Author Topic: Exhaust manifold question  (Read 1399 times)
Offline 7071 challenger
  • All you need is Dodge!
« on: July 02, 2012 - 12:55:26 PM »
Hi everyone...
I will need a complete exhaust system for my '71 Challenger with a 383. When I bought the car, it had headers on. I want to put it back stock, (manifolds). My question is: I have a driver side manifold here, from a 69 B-Body. Physically, it is very similar. The only difference I can see is, it doesn' t have treaded holes to bolt on the heat sheild, which is no big deal for me. What I want to know is, If I put it on, what head pipe will fit?  I mean, when you order head pipes, you have to give the exhaust maker your manifold casting numbers. Now, if I tell them it is 2843992, they' re going to tell me that isn' t a valid number for an E-body, which is true. My concern is the flange angle at the outlet. Is it the same as one of the possible casting numbers for E-body?  If so, which one?  Once a gain, I' m not that fussy for the look and I don' t really care about the heat sheild. I know the manifold I have will fit the engine fine, just want to know which pipe to order that will fit with the car.
Thanks to all
Robert
Re: Exhaust manifold question
« Reply #1 on: July 02, 2012 - 01:29:52 PM »
Call the exhaust company and ask them.  They'll know if that manifold will work with their system.
« Reply #2 on: July 02, 2012 - 11:12:45 PM »
With TTI they want the manifold casting #s , the flange is different between the 2 manifolds , the clocking of the bolt position changes & TTi will accomodate that change
