Looking for Rally wheels HELP
Author Topic: Looking for Rally wheels HELP  (Read 6528 times)
Offline EDGECRUSHER
Re: Looking for Rally wheels HELP
« Reply #15 on: July 04, 2012 - 05:39:41 PM »
The wheels from Vintiques are not very good , mine were not true and were very hard to balance.....the center caps are very cheep and are wobble when they turn. trim rings are all the same size , so if you by the wider rims the rings will  have a big space between the rim and ring...... (made in china)
are there any company's that make a better Rally wheel then?
« Reply #16 on: July 04, 2012 - 08:11:40 PM »
Well, you just got a bad set then.  No problems with mine at all.
Offline 1of1
« Reply #17 on: July 04, 2012 - 11:15:30 PM »
I have used the ones that I bought, Just not happy with them...I call them as I see them and VIN...just makes a cheap product... the paint on them just flakes off with a few changes of the trim rings! You get what you pay for, and  I did not think about it when I thought they were such a good deal... I srewed up!!! I should have looked harder for a better set...I have since had the stock rims straightened and repainted.....If you have your stock rims I would suggest referbing them....
1970 Cuda 383/335hp/4sp/V02
2006 FordGT40 Black Naked
Offline GreenFish
« Reply #18 on: July 05, 2012 - 11:19:44 AM »
I actually prefer the darker ones to make the paint pop but it would be very easy to swap them out if need be.
Not that it matters, but the dark center cap is for a 71, the silver is for 70.
Offline EDGECRUSHER
« Reply #19 on: July 05, 2012 - 12:11:55 PM »
yes it matters… i was a 70's style grey cap on a 70's car.
