just below your key, on the column can be turned and the key will come out. You probably dont have the linkage hooked up to the trans that came from the factory. The column cylinder will turn, so turn it counter clock wise to remove the key. If you notice under the hood, a little lever at the column by the firewall, this is the same piece you would turn. Nothing is broke
