Author Topic: Wilwood Brake kit front to back?????  (Read 738 times)
Offline GreenFish
« on: July 05, 2012 - 10:35:34 AM »
So I originally put the 4 piston wilwood brake kit on the cuda. I still have drums in the rear. I kept to the 4 piston set because I wanted to stay with stock 15 inch wheels..  Now I am considering 17's which means I can then go to a bigger 6 piston brake caliper and rotor.  So what to do with the 4 piston calipers?  Could I use them on the rear?  Could I get all the other parts for the drum to disc converstion and just use my existing calipers or is it something that would not be worth it?
Re: Wilwood Brake kit front to back?????
« Reply #1 on: July 05, 2012 - 10:55:35 AM »
I would contact Wilwood & see what parts are compatable front to rear
