Author Topic: Side Glass removal  (Read 932 times)
Offline ff6849
Side Glass removal
« on: July 05, 2012 - 01:20:25 PM »
I need to remove the door glass from my 1973 Cuda to prepare it for the paint shop, I have no idea where to begin, any suggestions or exposed diagrams would be helpful.  Everything else has been removed just need to accomplish this last item to get her painted. interior has been complete removed, along with front and rear windshields.
(__________]]]]]}~~~~
73 440 Cuda'
915 heads (mild head work, stock bottom end 10/9:1 compression)
A518 2600-2800 Stall
4.10 rear gear
TTI headers with 3' exhaust with  X pipe
comp XE274H cam
Hughes Roller Rockers
Holley Sniper EFI
Holley Street Dominator intake
MSD ignition
Re: Side Glass removal
« Reply #1 on: July 05, 2012 - 01:36:52 PM »
Do yourself a favor and do NOT remove the track assembly.  There's no need to remove it unless you have rust issues to fix around it.  The glass is easily removed.  There will be one bolt with a spring on the back side of it that holes the glass to the track.  There will be a second bolt that holds the crank mechanism to the glass.  That's it.  The glass comes out the top/side.  The plastic upstop doesn't need to be removed.  The glass will slide out the larger opening at the front of the quarters that is covered by that large rubber end seal.
Offline tman
« Reply #2 on: July 05, 2012 - 02:09:16 PM »
« Reply #3 on: July 05, 2012 - 02:27:07 PM »
It would help to read the question a little closer.  You need to remove the door glass...not the quarter glass.  Sorry
Offline dutch
« Reply #4 on: July 05, 2012 - 03:04:28 PM »
if you don`t lift the front rail with the glass, it`s gonna be tight and there will be tension on the glass. The window felts will have to come off too.  Don`t break it...
*** Bart ***
Offline ff6849
« Reply #5 on: July 05, 2012 - 03:37:18 PM »
Thanks for all your help,  I am glad to say the passenger side front and rear glass is out along with regulators, took many pictures of the disassembly and parts. Getting the front regulator was hardest part couldn't figure out  it came out through the top or bottom access hole.
73 440 Cuda'
4.10 rear gear
comp XE274H cam
Holley Sniper EFI
MSD ignition
