Author Topic: What is this Wiring Harness for Challenger?  (Read 876 times)
Offline ChallengerRt
« on: July 06, 2012 - 09:16:09 PM »
Attached are Pictures of harness I have had for 20 years, What is it for, Challenger? Has part number on one end, is foleded a little, hope this is all numbers, 435358 770618. Has a 6 plug , only 5 used to dash, other end license plate light, two single plugs, fuel tank sending unit, looks like reverse light 2 wire green & black, 2 prong t plug
« Last Edit: July 06, 2012 - 10:22:51 PM by ChallengerRt »
Offline Jamiez
  • Retro
Re: What is this Wiring Harness for Challenger?
« Reply #1 on: July 06, 2012 - 09:39:50 PM »
The spare harness I have for my 74 challenger has a 8 wire connector on the front with 7 wires going to the back.  The sockets the lights (both the backup and brake/parking lights) are wired directly into the harness.  It also has connections for the plate, fuel sender, and the dome light if I'm not mistaken.
Not sure if the earlier years were different but I don't think so.
« Reply #2 on: July 06, 2012 - 10:02:34 PM »
harness is not cut anywhere, it only has one bulb socket 2 wire, green & black. No other bulb sockets.
Tony
Offline MoparDealer1971
  • CDRJ Dealer
« Reply #3 on: July 07, 2012 - 11:15:13 AM »
Looks to me to a cut rear lighting harness.  The gray plug looks right for that.  Does it have a really long pink wire?  That would be the dome lamp lead that goes back and up the driver's B-pillar.
1971 Dodge Challenger - 2010 Plum Crazy Pearl, 318 4-bbl, 904, 2.5in Pypes Performance X-pipe exhaust, Hemi torsion bars, 2in rear drop springs, Hellwig Motorsports sway bars, 11.75in Drilled/Slotted front brakes
« Reply #4 on: July 07, 2012 - 11:49:15 AM »
No pink wire , where can you check part numbed, I recheck to see if is cut.
Tony
