The engine just died when cruising on the freeway
Author Topic: The engine just died when cruising on the freeway  (Read 3679 times)
Offline widing'cuda
  • 70 'cuda383 - BS23N0E
    • w i d i n g ' c u d a
Re: The engine just died when cruising on the freeway
« Reply #15 on: July 24, 2012 - 06:46:33 PM »
Found the problem, the fuel pump was loose. yes the bolts had almot falen out. I don't understand how this has happen. So it was not hitting the push rod. I replace it with a edelbrock pump. but i manage to crack the top of the fuel pump, just were the seal is. So I guess i have to replace it again :(
- Jørgen - Norwegian Mopar fanatic
1970 Plymouth 'Cuda 383 A833 8-3/4 3.23 suregrip
http://cuda.widing.biz/
