Author Topic: E-body tranny line routing suggestions  (Read 2182 times)
Offline hemi68charger
  • Charger Power!!
    • Houston Mopar Club Connection
« on: July 08, 2012 - 03:28:12 PM »
Hello All,
I'm helping a Bud with the restoration of his '71 Challenger R/T. OK, I'm in the process of putting the tranny lines he's purchased. Well, Hello TTI headers. I've always been an OEM-guy, so don't have much experience with installation of tranny lines on cars equipped with headers. Soooooo, any suggestions? From my end, the tranny lines hit the bottom tubes and hence won't position themselves properly at the fittings..
'69 Daytona 426 HEMI-727
'70 Superbird 440 - 4speed
Offline wiging19
Re: E-body tranny line routing suggestions
« Reply #1 on: July 08, 2012 - 04:40:14 PM »
 :popcorn:
Offline PlumCrazyChris
    • Mopar Muscle Cars of Austin
« Reply #2 on: November 03, 2012 - 04:46:44 PM »
I'm having the same problem.  So are you saying I have to make a custom set of tranny lines?  or just bend the **** out of the ones I have....
PlumCrazyChris
Round Rock Tx
70 Challenger 5.7, A518, A/C
70 Challenger 340 convertible (Gone to Sweden)
68 Barracuda (sold it too)
www.mopar.org
Offline moparmaniac59
  • Drive it like ya stole it!
« Reply #3 on: November 03, 2012 - 04:53:20 PM »
Why not try a 90 or 45 degree adapter, then the lines wouldn't have to be bent or at a minimum, bent just a little.
        Matt B.
Matt
« Reply #4 on: November 03, 2012 - 05:07:30 PM »
Where would the adapter be installed?  I don't see how that would work.....
Thanks for the input.
PlumCrazyChris
Round Rock Tx
www.mopar.org
« Reply #5 on: November 03, 2012 - 08:41:22 PM »
Remove the straight fitting from the transmission and replace them with a 45 or 90 degree fitting. They might be hard to find. When I installed my transmission, I broke one off flush with the tranny. I went to all the auto parts stores to find one & had no luck. I went to hydraulic services shop and bingo, lot of fittings.
Matt
« Reply #6 on: November 03, 2012 - 08:50:51 PM »
You can always order a fitting from these guys if you can't find the fitting locally. These guys are the largest supplier of fittings out there. http://shop.hoseandfittings.com/index.html
        Matt B.
« Last Edit: November 03, 2012 - 08:53:55 PM by moparmaniac59 »
Matt
« Reply #7 on: November 05, 2012 - 01:47:17 PM »
Well thanks for the input guys.
I ended up, just rebending them to fit up tight against the tranny and just slipp around the trans bellhousing.  They are very close to the headers though, so I'll need to build a heat sheild of some kind.
Thanks for your responses!
PlumCrazyChris
Round Rock Tx
www.mopar.org
