Author Topic: How do I take a rallye clock apart?  (Read 2552 times)
Offline Lockout76
  • Everything's a project...
« on: July 08, 2012 - 11:12:44 PM »
Just wondering if anyone knows or has a diagram on how to take a rallye clock apart, 72-74 style. Mine does not work and I am planning to repair it. I think I have to grind off rivets, but I hope not. I have the clock out of the dash, but that is as far I have taken it.
Did a search and found a link for a diagram, http://rt-eng.com/mediawiki/images/c/cf/EbodyRallyeClock1209.pdf, however it is forbidden at this time.
Any tips, photos, or walk-troughs out there?
Thanks, Mike
-1974 'Cuda 340, 4-speed, 3.55 Sure-Grip.
Offline Giveitawack
    • ebay
Re: How do I take a rallye clock apart?
« Reply #1 on: July 09, 2012 - 02:34:07 AM »
The clock is an electromechanic contraption and not very accurate.
DashWorx (earlier RT-Eng) sells a conversion kit to make it a quartz clock. If you have plans to take it apart and make it work, a quartz conversion would be the way to go. The kit has all small parts needed, rivets etc, and an instruction how to do it.
Offline Jamiez
  • Retro
« Reply #2 on: July 09, 2012 - 05:44:01 AM »
You do have to grind the rivets to get at the innards.  The quartz movement is much more accurate but you lose the tick tock sound that an electromechanical one makes.
I believe dashworx sold rebuilt ones or would rebuild yours if you sent it to them.  Obviously this costs more than a kit but you don't have to worry about screwing it up
« Reply #3 on: July 09, 2012 - 02:54:56 PM »
Age seems to take it's toll on the clocks.
Offline Jamiez
  • Retro
« Reply #4 on: July 09, 2012 - 04:03:41 PM »
The electromechanical clocks use a spring that winds and unwinds every 3 minutes or so (you can hear it).  Eventually the metal fatigues and the spring content changes resulting in less and less accurate time and then eventually it just stops all together.
Offline Lockout76
« Reply #5 on: July 09, 2012 - 06:21:50 PM »
Thanks for the info, confirmed what I thought. Definity going to do a conversion kit when I fix it.
Found one on eBay from clocks4cars, I will also look into dash worx.
-Mike
Offline Lockout76
« Reply #6 on: July 10, 2012 - 07:12:22 PM »
So how do you take the hands off the clock?
Or do they come off when the rivets are drilled out?
Offline Giveitawack
    • ebay
« Reply #7 on: July 11, 2012 - 03:39:46 AM »
They are pushed on. Pull the second hand off, then you see how the others are pushed on.
Offline solarguy
« Reply #8 on: July 11, 2012 - 02:23:00 PM »
I have those RTE instructions saved to a PDF file.  It's too big to post as an attachment here.  PM me your email and I'll forward them.
Offline ragtopdodge
« Reply #9 on: August 14, 2012 - 04:50:13 PM »
Drill the rivets out from the backside.  Don't throw them out and re-glue them on after the conversion.
'70 318-auto Chally 'vert
06 300c SRT8
04 2500 QCLB 4x4 HO
Offline 6PakFish
  • Move Over Power Approaching Rapidly!!!
« Reply #10 on: August 25, 2012 - 07:24:12 PM »
Howdy folks, I just added the quartz movement to my clock but I'm having problems with peening over the new rivets. Any hints on how to do it. The Directions from RTE said to use a small hammer to do this but I'm not having any luck with it. I have EFFED  :banghead: up the white face that I just painted trying to do this, I'm gonna have to get the new decal off and refinish the face again. The pic is before.
