Author Topic: 340 oil pan removal.  (Read 1075 times)
Offline jforest1
« on: July 09, 2012 - 09:33:36 AM »
Just trying to plan out some work I'll be doing.  Will I need to remove the steering link that runs under the oil pan to remove the oil pan?
If so, tie rod puller disconnects, but how do I reconnect it to the tie rods?
JF
'73 Cuda 340 Slapstick, A727 Torqueflite Transmission, Edelbrock Thunder Series AVS 1806, Vintage Air Gen IV A/C system
Re: 340 oil pan removal.
« Reply #1 on: July 09, 2012 - 09:42:43 AM »
Yes , I just use a hammer & hit the side & they pop it without damage to the seals
Offline jforest1
« Reply #2 on: July 09, 2012 - 10:33:05 PM »
Sounds like you are describing disconnecting them without a tie rod puller.
So how do I reconnect?  I was thinking it may be something you press back on but underneath the car?
JF
Offline PlumCraZRT
« Reply #3 on: July 09, 2012 - 11:09:18 PM »
JF
Correct, he's saying just hit them with a hammer instead of using a puller.
Just use the nut to 'press' them back together by torquing to spec.  The specs would be found in the service manual.
mmmmm.... Mopar.... *drool*
Offline jforest1
« Reply #4 on: July 10, 2012 - 10:30:36 PM »
Yeah I just purchased a new Pitman Arm because the side that bolts to the connecting rod in much the same way as the tierod was stripped and some kind of glue used to keep the nut attached instead of the cotter pin.  Made me concerned that the previous owner re-connected them improperly, and f***ed it up as I might.
Thanks.  That's what I needed to know.
JF
