Author Topic: Major decision time.  (Read 1966 times)
Offline msbaugh
Re: Major decision time.
« Reply #15 on: July 10, 2012 - 05:13:26 PM »
Regardless of what you end up putting together, you should spend some time with that spreadsheet and make sure you are really getting what you want.  I spent a lot of time with that when I was putting my engine together and it paid off.  Lastly, I think this whole mess would have been avoided if you had a spreadsheet like that before you ordered.
I've played around a little bit with your spreadsheet.  Very good way of planning out a build, I can see how using it would really simplify things for him regardless of wheather or not he chooses to start over.  That's saved to my desktop!  :thumbsup:
« Reply #16 on: July 10, 2012 - 06:02:19 PM »
It's kinda obvious you really want the 400 instead of the 440 block. Take the hit and get the kit for the 400.  It is simple enough to build what you had and achieve what was needed. ALL STROKER ASSEMBLIES need more than just balancing. Something will not be perfect and have to be worked on. Wrist pin or 2 too tight, crankshaft journal needing to be a little flatter, rod side clearance needing adjusting...ieieie..
Your kit was probably around .012 or so in the hole for piston to deck height.  You didn't say stock stealth heads or cnc ported. The chambers sizes need to be addressed.  I usually do or have my engines balanced local.  Once you have that 400 block assembled, let us know how it runs. Hughes doesn't make the kits, only supplies the parts and does some machine work. Even 440 sorce kits need machine work.  You will be pleased with any direction you go in once it is machined, assembled and you hammer down.
Offline MJS73
    • Mike's 1973 Challenger
« Reply #17 on: July 10, 2012 - 08:58:35 PM »
For what it's worth, Hughes designed the top end of my motor and it is completely excellent.
www.mikes73.com
Offline PlumCraZRT
« Reply #18 on: July 11, 2012 - 05:45:44 PM »
Glad somebody is getting use out of it!   :woo:
I sorta lied... I made that spreadsheet in about 10 min at work, but I was using a duplicate that I made at home during my build.  Really helped me get a hand on everything I had done.
mmmmm.... Mopar.... *drool*
