Without this thread becoming a peeing match, can we fix this?. You haven't answered any of my questions yet. It
seems that you're only 1/2 point from your desired compression. Depending on what type of pistons you have, what the deck height is,
and possibly using different head gaskets, it is very possible that you can easily lower the comp. ratio without
changing the pistons or having the rotating assy rebalanced. If you couldn't answer their questions about chamber size, deck height,
or even what cam profile you were going to use, they may have sent you what you needed. You stated in a quote " most
of the members on here don't know why they are talking about when they say you don't need that much compression." Is this an
accurate quote? Or can you clarify the statement please? I'm sure everyone on here wants to help but you got to quit jumping
the gun before you have all of the information you need to make a correct decision on what is needed. Good Luck.
