Author Topic: wiring question with MSD  (Read 862 times)
Offline Glennster
« on: July 09, 2012 - 08:22:25 PM »
I took the plunge and got an MSD Distributor (8534), a Blaster Coil (8202) and a 6AL(6425). Also got wires.
I hate wiring, I'm always intimidated by this stuff. Sooooo.... Do I bypass the resister?
Can you guys give me a few tips or point out any potential pit falls that I may run into?
As always.... THANK YOU for any assistance!!!
Re: wiring question with MSD
« Reply #1 on: July 09, 2012 - 10:42:01 PM »
The resistor is eliminated from the ignition cct. When you wire up the MSD box, you power up the (i think) red wire with both the brown and blue from the ballast resistor (connect all three together). The MSD obviously needs power on 'start' and on 'run', and thats what tying the brown and the blue together do for you. After you do that, the resistor is out of the cct.
Another issue may be the tach. If you have a stock tach, you need either a tach adapter from MSD or replace the innards of your tach with a kit from RT eng.
I really liked the increased response in my car with the MSD in the bottom end. Hopefully you will like your ignition upgrade.  :cheers:
« Reply #2 on: July 10, 2012 - 12:22:08 AM »
Dodj has it bang on as usual  :2thumbs:
Offline Glennster
« Reply #3 on: July 10, 2012 - 03:14:29 PM »
Does this mean I can remove the little orange Chrysler electronic module? How about the wires that come off of it, just tape them up?
THANK YOU for the help Gentlemen!
« Reply #4 on: July 10, 2012 - 04:56:57 PM »
Yes you can remove the orange box since the 6AL replaces it. I don't know about the wiring though. Did you get a wiring harness with the 6AL?
