Author Topic: E-body engine wiring and MSD  (Read 1904 times)
Offline hemi68charger
  • Charger Power!!
    • Houston Mopar Club Connection
« on: July 11, 2012 - 09:17:18 AM »
Hey gang..
Question:
Putting together my friend's '71 Challenger R/T. He has bought all new harnesses.. He purchased the engine harness that incorporates the Chrysler-electronic ignition. But, he's planning to install MSD on it. Soooo, should he have a regular harness or will I be able to used the Electronic-version and just go ahead and install?
'69 Daytona 426 HEMI-727
'70 Superbird 440 - 4speed
Re: E-body engine wiring and MSD
« Reply #1 on: July 15, 2012 - 10:04:29 AM »
The ECU plug is obsolete unless you use an MSD using the 5 pin connector . the red trigger wire has to be connected to the blue & brown wire at the ballast so it will start & run
  • Charger Power!!
« Reply #2 on: March 12, 2013 - 07:52:08 AM »
We ended up just getting a completely new OEM harness, so no "unused terminals" now... Looks nice and tidy...
