Author Topic: Oil pan for my 360 have a couple questions  (Read 1503 times)
Offline Barracudadan
« on: July 11, 2012 - 09:47:41 PM »
The shop where my engine is being done discovered a JB weld repair on my oil pan rather than weld it correctly I would rather just buy a new one. I know Milodon sells this one http://www.summitracing.com/parts/MIL-30755/?rtype=10 and then there is this one from Summit http://www.summitracing.com/parts/SUM-G3536/. Anyone use the Summit pan? I like the price but don`t want it if it fits like crap.
My main question is when you read the specs on both pans it says stroker clearanced "NO" will I have clearance issues with these pans since I am going with a stroker motor? If so what oil pan will work?
Re: Oil pan for my 360 have a couple questions
« Reply #1 on: July 11, 2012 - 10:20:53 PM »
I have never used the Summit pans but they look OK , the clearance problem should be with the windage tray & pick up tube if there is any problem at all !!
Offline calicuda70
  • 2 evil 70's and 1 BAD 11
« Reply #2 on: July 12, 2012 - 02:13:12 AM »
try out this mancini i run it on my 360 a bit pricy but well made and it an 8 qt plus its nicely tucked under the car unlike the milodon thats iff you go with a deep pan
http://chucker54.stores.yahoo.net/man360supstr.html
70 'Cuda 5.7 Hemi protouring resto
70 Challenger 360
11 Challenger SRT8 392
« Reply #3 on: July 12, 2012 - 10:29:35 AM »
No windage tray comes with this pan is one even necessary? I didn`t plan on using one.
Nice pan but that is a bit too much for me and I would prefer a stock looking pan if possible, anyone know for sure if clearance is an issue on a stroker with a stock type pan?
« Reply #4 on: July 12, 2012 - 10:31:47 PM »
The windage tray is attached to the main caps & sits inside the oil pan & is worth using as it will free up 15 hp or so
Offline cameron2502
« Reply #5 on: July 12, 2012 - 11:49:47 PM »
I put a Kevco pan on my cuda and it fit good, they have a website and tech help to tell you what you need.
