Author Topic: Johnson Lifters  (Read 1108 times)
Offline AMXguy
Johnson Lifters
« on: July 12, 2012 - 05:37:45 PM »
I hit the wrong button and removed the subject I guess? I didn't know you could do that.
Anyway,  the Crower Premiums are Johnsons, I'm not sure about the Crower Camsaver hi - lube lifters but they replaced the ones with the oil hole for the cam with a flat spot .  the idea is good and my searching seems to show nothing but good said about them.
It seems like a no brainer to put more oil on a flat tappet and they claim no more than 1 or 2 lost oil PSI .  any comment?
1970 R/T SE Challenger
 1970 Superbee
 1969 S code Mach 1
 1967  GTO
Re: Johnson Lifters
« Reply #1 on: July 12, 2012 - 08:23:20 PM »
They're called EDM lifters. May change pushrod height. I put them in my engine and the geometry looks O.K. so far.
http://board.moparts.org/ubbthreads/showflat.php?Cat=0&Board=Racer&Number=6585939&Searchpage=1&Main=6585593&Words=+Cuda_Mike&topic=&Search=true
Offline AMXguy
Re: Johnson Lifters
« Reply #2 on: July 12, 2012 - 08:38:31 PM »
These are standard lifters with a flat spot below the ring to allow oil to get to the lifter, same effect but a different style.
 1970 Superbee
 1969 S code Mach 1
 1967  GTO
Re: Johnson Lifters
« Reply #3 on: July 12, 2012 - 08:50:01 PM »
I bought mine from Johnson Lifters. They're basically AMC lifters modified from what I heard.
EDM lifters are only available as a flat tappet "solid" lifter.
