Author Topic: Filling body side molding holes  (Read 1344 times)
Offline vpittman
« on: July 15, 2012 - 05:00:37 PM »
Hey,
Just removed the body side molding from my '73 cuda (ugly aftermarket kind) and wanted to know the best way to fill the holes...
Just trying to clean it up now, but it will have to have a repaint down the road
Thanks !
Victor
Offline torredcuda
  • Epping NH joined 11/23/03
Re: Filling body side molding holes
« Reply #1 on: July 15, 2012 - 05:32:30 PM »
The correct way to do it is weld `em up.
Jeff
72 Barracuda 340/4spd  Torred
04 Ram 2500 5.7 Hemi
Offline 72bluNblu
« Reply #2 on: July 16, 2012 - 03:31:14 AM »
And I'll go a bit further- welding them up is the only RIGHT way to do it. I suppose you could lead them if you know someone that can work lead, but that'd be harder than welding them up.
Body filler will absorb moisture, and since it will hang out the back of the hole, there's no way to seal it properly. The end result will be the filler will absorb moisture, swell and crack the paint, and even cause rust damage around the holes.
Offline shawge
  • Zoiks!!
« Reply #3 on: July 17, 2012 - 02:40:36 PM »
+1 for welding them up.  A copper backing plate works well but can be a PITA in the wheel well area.  Got to get creative on holding it in place.
- Jerry
Offline vpittman
« Reply #4 on: July 17, 2012 - 11:27:25 PM »
Thanks everyone...
Looks like welding is the way to go
