We need more info , I assume 36* total timing which is right , 245 is far too high , 225 max
Clutch fans are the most efficient , electric not so much . if you are running electric fans that can draw more power then the alt can supply , therefore alt problems !!
Shrouds are a huge help .
Are you using a 440 source water pump housing , theyare very restrictive ?
What thermostat ? 180* is best .
Do you have a wire coil int the lower rad hose to prevent it collapsing .sucking shut ?
What do the plugs look like you could be running very lean creating more heat .
